New Topic New Reply
Author: Subject: Sierra hand brake cable
macspeedy
posted on 8/4/03 at 08:56 PM Reply With Quote
I know this was discussed at length not that long ago but i cut the cable in the middle, do the u clamp things pass a sva, or are there other preffered methods??
chrisg
posted on 8/4/03 at 10:09 PM Reply With Quote
I don't know wheather the clamps are going to pass the SVA (someone will), but without an x-ray machine or a series of mirrors,sticks, pulleys etc..........
How would they know?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
MK9R
posted on 9/4/03 at 06:51 AM Reply With Quote
What we ended up doing was this:-
Make a U bracket for the end of each cable to fit to the balance bar by welding 2 strips of steel onto the female part of a brake pipe connector. Then pass the threaded male part of the brake pipe connector onto the cable, followed by a piece of steel bike pipe which is flared at the end. Spread the handbrake cable at the end and then then solder it. The solder flows all through the brake pipe and also creates a nipple at the end. When you screw the brake pipe connector together the nipple is also squashed inside. We tested the strength of this on a test piece first and the cable snapped and the cable did not pull through at all. See my photos section
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
New Topic New Reply
