mackei23b
| posted on 21/12/06 at 12:16 PM |
shocks - which ones??
Hi there
Well, I'm about to order some coil overs, looking at GAZ or PROTECH for my Indy
What would you recommend?
Many thanks
Ian
P.S. what spring rates have you used if you have a BEC
MattCraneCustoms
| posted on 21/12/06 at 12:21 PM |
If you search through the threads you'll see I posted one about this not long back, regarding locost. Protec I think ending up getting the
majority vote.
Speak to Procomp, they know they're stuff regarding this
Matt
ned
| posted on 21/12/06 at 12:45 PM |
I believe protech use a slighter newer valve design and are ally bodied which is about the only real advantage between the two as I understand it. MK
also supply protech shocks as standard on the deluxe kit i believe
Ned.
beware, I've got yellow skin
mark.s
| posted on 21/12/06 at 04:31 PM |
hold a gaz in one hand and a protech in the other......then ring MK , they do really good deals on them
cheers mark
andrews_45
| posted on 21/12/06 at 07:24 PM |
Procomp, has a suspension dyno machine and has analised all of the major manufacturers ones. Contact matt and ask him. He did tell me the other
week, some look the part but are badly valved and are hard to balance the damping. IIRC Gaz came out top
Hellfire
| posted on 22/12/06 at 04:18 PM |
Are you on the Procomp books???
andrews_45
| posted on 22/12/06 at 06:55 PM |
No, why? Who else do you know that has analised most brands of suspension on a dyno???
I always find it best to deal with facts? Do you have a problem with this?
macnab
| posted on 22/12/06 at 07:01 PM |
my protec ones are holding up very well, still look like new and their about 4 years old now (one day they might even be used on the road... )
procomp
| posted on 23/12/06 at 10:02 AM |
Hi if mackei23b dose want to ask me for any advise on his shocks please feel welcome to do so.
But frankly the best dampers for any car are the ones that are valved correctly and are suitable for the job. I do not have any paticular favorits
that i recomend as a good working damper is a good working damper.
cherrs matt
