scotlad
| posted on 3/11/03 at 02:34 PM |
wiring loom
Anyone suggest a wiring loom i can purchase that gives connectors for steering column switches and fireblade engine connectors? Martin at MKs loom is
a wee bit pricey at £150 odd
greggors84
| posted on 3/11/03 at 02:41 PM |
I bought mine from premier wiring, it was £100 and thats for the sierra one. Not sure of their number, but if u give them a call, they may do one for
a bike engine.
Chris
The Magnificent 7!
bob
| posted on 3/11/03 at 07:51 PM |
http://www.premierwiring.co.uk
0800 0742789
not sure if the freephone is still in use but worth a try,really nice people to do business with and a great product.
[Edited on 3/11/03 by bob]
scotlad
| posted on 4/11/03 at 12:30 AM |
Excellent. thanks guys shall give 'em a call!
MK7
| posted on 4/11/03 at 08:55 AM |
Switch burnout
I think any of the looms can use the column switches, however, the problem is that the switches won't last. I had this discussion with the
manufacturers of the MK loom.
With all the lights on (Main beam, headlamp and side / tail lights) the headlamp switch is carrying about 30 Amps.
Ideally you need to fit additional relays. I've posted drawings about how to do this.
As an aside, untli MES re-design the MK loom with adequate input from MK, I wouldn't buy one.
Russell
bob
| posted on 4/11/03 at 09:03 AM |
The premier wiring loom already has the relay sockets wired up for dip and main plus indicators and wipers if needed,its just a matter of fitting a
few wires to determine wether your switches are 83BG or 87BG wiring.
All the info supplied with the wiring kit was very easy to follow and the fuse box is already wired too which was a great help,even some convoluted
tube and a load of tie wraps and a crimping tool are included among other bits.
scotlad
| posted on 4/11/03 at 09:21 AM |
i'll give premier a call, and i'll check there are the appropriate bits for relay control. thanks again guys
