zxrlocost
| posted on 18/10/05 at 08:44 AM |
rear stub axle
Mk told me that I need to grind the 2nd bigger toothed part on the drive shaft (ABS RING?)
is it just as simple as grinding then!
seems a bit to me?
dont want to do it then do something wrong
any help please
cheers
chris
mookaloid
| posted on 18/10/05 at 09:12 AM |
Yes the toothed bit for the abs sensor won't go through the MK upright.
You can just grind it off but a neater job is turning it off using a lathe. A local machining company will be able to do this for you for beer
money.
Mark
