stevec
| posted on 30/12/05 at 08:13 PM |
Do we bung the hole or not
I of course refer to the end hole in the rear end of the chassis lower rail on a Indy.
Do we bung up or leave to breathe?
Your opinions will be helpful.
Steve.
donut
| posted on 30/12/05 at 08:38 PM |
You can get 1" square plastic feet for garden furniture and stuff but i have yet to find any for sale.
Avoneer
| posted on 30/12/05 at 09:01 PM |
B&Q.
Pat...
| posted on 30/12/05 at 09:37 PM |
never leave it open, you'll get moisture inside and it will rot from both ends. Id silicone a stopped in. On my own constuctions i mitre the
corners, no holes, no stops and the option of sticking oil inside several tubes at once if you want.
stevec
| posted on 30/12/05 at 10:14 PM |
Thanks folks. As I thought, I will give it a blast of waxoil before I seal it.
Cheers.
bob
| posted on 30/12/05 at 10:22 PM |
i made a bung out of the black silicone adhesive i used to glue the panels on,it did the trick ok
Messenjah
| posted on 30/12/05 at 11:44 PM |
if you bung it and there is a small hole somewhere moisture can be forced in by air pressure around the hole when traveling at speed and not be able
to get out tho ....
wy not leave it open and pump the chassis full of clear waxoyl
caber
| posted on 30/12/05 at 11:49 PM |
Square plastic finishers at 1" come on a lot of office furniture , check the desks at work
Caber
Danozeman
| posted on 31/12/05 at 09:16 AM |
Desks and tables at work mate. Get searching and fold up a bit of card to put under so nobody notices it rocking. They do them in BnQ aswell but
why buy when u can have one for free. Silicoon them in. Theyl seal a treat.
Dan
Ian Pearson
| posted on 31/12/05 at 09:48 AM |
to get out tho ....
It's a car not an F16!
Avoneer
| posted on 31/12/05 at 10:16 AM |
Don't ever "fill" the tubes with waxoyl !
You'd be suprised how hot the chassis tubes get, especially near the engine. The waxoyl heats up and runs out of every rivet hole and orifice
and then dries. It's a bugger to clean off.
Speaking from experience and on behalf of a few other who have done the same.
Pat...
stevec
| posted on 31/12/05 at 11:40 AM |
I will give the waxoil a miss ,I dont do dirty cars,
Cheers.
Avoneer
| posted on 31/12/05 at 11:50 AM |
A quick light spray is a good idea - just don't "fill the tubes".
Pat...
DEAN C.
| posted on 31/12/05 at 04:50 PM |
Hi,everytime I drilled a hole in my chassis it got the waxoyl aerosol and thin tube stuffed in and I gave everything internally a good blast.
Smells lovelly coming out of the top engine bay tube rivet holes just above the exhaust It does help to spread it around though.
A rag with thinners wipes it off no problem,does smell at first though
I've seen a few old kit cars with rotten tubes,including a Cateringvan.Better to use waxoyl than not i'd say,its up to you.
Once I've finished a project why do I start another?
