darrenga
| posted on 19/8/06 at 01:13 PM |
fuel tank for indy
is this fuel tank suitable for the indy
darrenga
| posted on 19/8/06 at 01:46 PM |
£70 mk £105
Guinness
| posted on 19/8/06 at 01:59 PM |
Just measured my MK Tank.
760mm wide x 210mm high x 180mm front to back.
Width wise mine is about 10mm per side narrower than the chassis rails that go down to the bottom rail at the back.
Height wise should be OK, depending on what you do about boot box.
Front to back is going to be very tight at 230mm. It will sit on the box section behind the diff and on the round tube at the rear. My MK tank has a
25mm gap between the diff and the same between the tank and the rear panel.
HTH
Mike
mad-butcher
| posted on 19/8/06 at 02:50 PM |
one inlet, one outlet, provision for sender
but no mention of a vent
DEAN C.
| posted on 19/8/06 at 04:38 PM |
Hi,as chris mentioned already,
try MK engineering(Martin Keenan) himself I would think his price would be similar to the one you have quoted.
Martin made my tank to my own design for about the same price.
[Edited on 19/8/06 by DEAN C.]
Once I've finished a project why do I start another?
darrenga
| posted on 19/8/06 at 05:08 PM |
price on mk engineering site is £105 price of ace is £70, was looking more at the capacity mk say there holds about 5 gallon the ace one says 7 gallon
alister667
| posted on 19/8/06 at 06:01 PM |
Or a 5 Gallon Jerry Can for (I think) £15.
Small bit of extra work involved, but hey, this is locostbuilders right?
http://members.lycos.co.uk/alister667/
theconrodkid
| posted on 19/8/06 at 06:12 PM |
the weight of 7 gallons of fuel will seriously upset the handling as its behind the back axle,after burning 2 gallons of fuel you will want to stop
for a cuppa/break
who cares who wins
pass the pork pies
