Coopz
| posted on 31/12/09 at 05:43 PM |
Trim
So I'm a little confused done lots of searches but haven't really come up with what I was looking for.
I'm wondering what trim people have used when coming to fit body panels.
For example on the bottom of the side panels to fill the panel gap am I ok with 25*3mm self adhesive foam strip?
What trim is used on the scuttle/bonnet/nosecone top of side panels?
Also how have people fitted there dashes to the scuttle I have a new style mk dash any trim or just riveted?
Cheers toby
ReMan
| posted on 1/1/10 at 10:15 AM |
Better to use a solid material, soch as plastic strip or offcuts of the MK inner trim panels. You only need small pieces at each rivet so they can
pull up tight without distorting the panel
Nothing under the scuttle, thin adhesive foam under the nose and bonnet where they sit on top of the side panels
Not sure what the new dash looks like, so cant comment on the trim, but would be inclined to make it detachable with screws tarther than
rivets?
Cheers toby
Stuart_B
| posted on 1/1/10 at 11:17 AM |
hi,
for the side pannels to chassis i used tigger seal to fill the gap, but riveted teh front section:
see here:
  5
and for the scuttle, bonent and nosecone to chassis i did not use any.
but for the battery tray to scuttle and chassis i used some foam strip.
and as for the dash i have not seen.
cheers
stuart
Coopz
| posted on 1/1/10 at 11:56 AM |
Cheers guys will get ordering few bits and try get these side panels on!
ReMan
| posted on 1/1/10 at 01:01 PM |
Actually, as per the pics in my archive i did not use any tape bonnett to panels only under the nose. beer still working!
