shortie
| posted on 21/6/04 at 11:11 PM |
Fuel Tank
Just started looking at my fuel tank this evening and wanted to check something.
One end has the filler pipe and another connection which seems to need drilling through, is this a breather\valve connection?
Also I take it the connection the other end is the one to the fuel pump?
ta,
Rich.
James
| posted on 21/6/04 at 11:13 PM |
Martin told me the blanked off one is to be used if you fit injection and need a return- although no doubt it has other uses aswell!
Atb,
James
| posted on 22/6/04 at 11:56 AM |
Shortie,
as James stated, either a return for fuel injected engine or drill through for a breather. One at t'other side IS for fuel pump.
shortie
| posted on 22/6/04 at 06:40 PM |
Thanks guys I want to fit a breather so I'll probably drill through and fit a breather valve.
Rich.
| posted on 23/6/04 at 07:25 AM |
Why not drill through the breather with a small (3mm) drill and just attach a length of hose to vent the tank.
