zx12r dug
posted on 25/6/14 at 11:40 AM |
nut thread
Hi guys does anyone know what thread the transit top drag link nut that goes inside the mushroom is some how ive lost both of mine or my little helper
(3yr old) has put them somewhere . Thanks dug
Myke 2463
| posted on 25/6/14 at 01:31 PM |
Usually M18 x 1.5 Fine, R/Hand.
Be Lucky Mike.
CosKev3
| posted on 25/6/14 at 01:36 PM |
Quick search says if its not a Metric thread it will be a 1/2" UNF pal
Think thats the thread that goes into wishbone?
| posted on 25/6/14 at 01:55 PM |
This sort of problem is the bane of my existence it is probably M12x1.5 but even if it is M12 it could be anything. 1.25 or 1.75 pitch or even
5/8" or 11/16" UNF
Depends entirely on what company manufactured the part you are going to have to measure the thread major diameter, and also the pitch.
If you haven't got a thread pitch gauge then comparing the thread with a bolt of known pitch, whatever you do unless you are 100 percent sure
don't try screwing nut on using anything stronger than your fingers.
[Edited on 25/6/14 by britishtrident]
