shortie
| posted on 23/11/04 at 09:13 PM |
Propshaft\gear linkage
Just started looking at fitting the prop and gear linkage kit and the two look quite close together. Just wondered if other people have found the
same thing, I am using the MK gear linkage kit and my prop is the thicker sierra type.
ta,
RIch.
| posted on 23/11/04 at 09:38 PM |
Our's looks like this:
All bits from MK too...
HTH
shortie
| posted on 23/11/04 at 09:43 PM |
Cheers Hellfire, can I be cheeky and ask if you have any pics you could send me via email that show the gear linkage including the lever setup etc and
a bigger pic of the pic above.
mailus@shortshouse.co.uk
They would be really really helpful.
thanks,
Rich.
| posted on 23/11/04 at 09:48 PM |
They are in our website build diary December near the top and March near the bottom. Some are enlargeable from the site.
shortie
| posted on 23/11/04 at 09:55 PM |
thanks Hellfire,
I think that the problem is that I was trying to get the lever in the middle of the tunnel and it seems to be ok if I move it to the left. I guess
it's all pretty close down the tunnel anyway.
thanks,
Rich.
mad-butcher
| posted on 24/11/04 at 08:37 PM |
hope you haven't done your brake pipe yet and have the same problem hellfire and i had. I put a slight bend in the long rod to keep it hard over
to the left of the tunnel
tony
shortie
| posted on 24/11/04 at 11:17 PM |
May well have the same issue with the brake light sensor, fingers crossed but I must say I am a little worried!!
May get away with it looking at it, can always move the pipe lower or bend it round the linkage if I need to.
http://www.shortshouse.plus.com/files/MK/brake_pipes.jpg
Rich.
[Edited on 24/11/04 by shortie]
shortie
| posted on 24/11/04 at 11:56 PM |
brake pic
