woodster
| posted on 24/2/05 at 10:13 AM |
GT1 Weights
I spoke to simon yesterday he wants to know and i hope i've got the question right....... Does anyone whos built a GT1 have the braking weights
... something to do with the sva form.
Cheers Woodster
Mike S
| posted on 24/2/05 at 11:53 AM |
Woodster,
I would think that Simon is probably looking for the max axle weights. I undersatnd that these are required for the SVA form.
I'm still building my GT1 and am trying to get it finished by the spring! (when the Gillingham SVA Centre re-opens)
Unfortunatly I don't know the weights but will also need this info.
Jon Ison might know, though I,m not sure his GT1 has been through SVA?
Regards
Mike
| posted on 24/2/05 at 12:46 PM |
If its for the SVA form, then I'm sure its the design axle weights you are after. As MK Engineering designed the GT1, just give him a bell.
I'm sure Martin will know.
woodster
| posted on 25/2/05 at 10:02 AM |
Thanks for the help I'll give Martin a call.
Cheers Woodster.
Jon Ison
| posted on 25/2/05 at 07:55 PM |
If you go 450kgs front and 550kgs rear you will be well in, giving you a total of 1000kgs, Mr SVA will calculate the gross weight of car including
passenger wich needs to be under your "design weight".
550 kg car (all fluids full) plus 2 persons maybe another 200kgs see's you well under 450 front and 550 rear.
I know of at least one person that filled this part of the form in under weight and Mr SVA allowed him to adjust/alter it there and then.
woodster
| posted on 26/2/05 at 09:31 AM |
Thank You Jon I'll pass that on.
Cheers Woodster
