mkblade
| posted on 2/7/05 at 10:08 PM |
front indicators
ive put my front indicators on the nose cone (small bike ones) they sit to close to the nose cone. they need to come further out about another 3cm
.can anyone advise on how they done this .i was thinking of getting a length of thredded studding (b&q) using that with some sort of rubber cover
over the threads ??
thanks
simon
shortie
| posted on 3/7/05 at 06:21 AM |
I made some up using a length of plastic rod which was the same diameter as the indicater stalk (pic attached)
Cut to length and then drill a hole straight through the middle. Then tap each end of the hole (I think it's an M8). Then you just thread the
wire through the hole and screw the indicator into it. At the other end you just use a bolt to go through the nosecone and then screw into the other
end of the plastic rod.
If it's only 3cm I think I have some of the rod left and could make you some on the lathe, maybe best to make 5cm to be on the safe side.
I made some for MAB on this site and he passed SVA no problem with them. After SVA you can remove them if you want.
I see you are in Croydon, I work in Kingswood so could even drop them into you at some point if you want which would save postage.
Rich.
  Indicator stalks
[Edited on 3/7/05 by shortie]
mkblade
| posted on 3/7/05 at 10:57 PM |
hi rich
i made some today used a long bolt m10. i think then a piece of tubing as the spacer yjen covered it in wiring covering stuff (cant spell the correct
word for it).
they look ok there extended out to 5cm now .
i think yours look nicer mind you ,thanks for the other of making some for me i will see how these go i will let you know thanks simon
shortie
| posted on 4/7/05 at 11:08 AM |
No probs, make sure you check they are the correct distance from the side, and remember it is at the widest point which is the edge of the rear arch
and not the front cycle wing.
Rich.
