zxrlocost
| posted on 4/12/05 at 01:53 PM |
R1 indy Help !!!!
Hi
was just about to fit the cradle ontop of my engine theres 4 mounts on the top two at front which are closer
and the two at the back which are further apart
I can get the further apart ones on fine
but then the two at the front are just basically in the middly of nowhere#
is there something Im not doing right???
ta chris
kurt
| posted on 4/12/05 at 04:50 PM |
Are you sure you've got the right cradle from MK, mine went on really easily? There should be 4 bolts into the engine block from the cradle and
1 long bolt at the back of the engine which runs through a mount on the main chassis. The only problem I had was getting the right bolts, they are
M10 but a very fine thread pitch. M10 bolts come in about 4 different pitches so it's one of the two fine ones.
OX
| posted on 4/12/05 at 05:19 PM |
i struggled to get my bolts in with mine and shed did with his
chris ,when you ring me it doesnt show up your phone number so i couldnt ring you back .
zxrlocost
| posted on 4/12/05 at 05:56 PM |
X directory mate
put picture in my archive engine cradle
look at the mount on the left its miles away
ta chris
zxrlocost
| posted on 4/12/05 at 06:27 PM |
done thanks OX
