zxrlocost
| posted on 6/3/06 at 09:33 PM |
can I split my prop in two?
can I split my sierra prop in two as Im having difficulty fitting it without it wedging etc etc and its scratching everything
is it just that 17mm bolt
just undo then put back together with locktite
whats the best thing to grip the prop with to stop it from spinning as its very fragile
ta chris
Avoneer
| posted on 6/3/06 at 09:40 PM |
You can split it.
Har work to get the bolt out though - you can only turn it a fraction at a time.
There's a big shimmy washery thing in there as well with a small peg on it.
Two bolts in the end flange and a long bar between the bolts and resting on the floor.
Hope that helps,
Pat...
zxrlocost
| posted on 6/3/06 at 09:53 PM |
ok cheers
mad-butcher
| posted on 7/3/06 at 09:05 AM |
piss easy with a ratchet spanner
