macspeedy
| posted on 19/3/03 at 09:10 PM |
rear wings
I have trial fitted the rear wings to my car and it seems that there is no direct fixing possible to the chassis, how have other people fitted them?
Jim
| posted on 19/3/03 at 09:32 PM |
I bolted mine to the fibre glass side and rear panel. I could not think of any other way. They have both stayed on the car so far.
Jim
CairB
| posted on 19/3/03 at 09:35 PM |
Mine are attached the same way using M6 screws with spreader washers and wing beading between the arch joint and the panels.
Mine were also still attached when I had a look 10 minutes ago
zetec
| posted on 22/3/03 at 10:36 AM |
You can rivnut to the bottom chassis rail, the tube you rest your arm on and the top shock turret, the rest do as mentioned.
