New Topic New Reply
Author: Subject: type 9 gearbox mount
Bluemoon
posted on 3/4/06 at 10:44 PM Reply With Quote
I need to clear this up. As I'm about to fit gearbox and engine..
How many have used the serria dooner rubber gearbox mount on their indy?
Is it o.k. or two soft?
Should I use a westfield one?
But is the westfield mount a direct replacement for the sierra item?
Dan
James
posted on 3/4/06 at 11:22 PM Reply With Quote
Dan
The Westie one is not a direct replacement.
It makes the gearbox sit about 1" higher. I've adjusted my chassis to compensate.
I can understand you not wanting to modify your Indy chassis but the Westie mount is much much stiffer than the Sierra. So if you can come up with a solution that allows you to use it without chopping your chassis around then I would.
HTH,
James
BMF
posted on 4/4/06 at 07:47 AM Reply With Quote
I have a westie mount spare if you want one.
£10 delivered
tim windmill
posted on 4/4/06 at 09:38 AM Reply With Quote
i used standard sierra gearbox mount on my indy with no problems
New Topic New Reply
