jabbahutt
| posted on 14/8/06 at 07:32 PM |
does it matter
Hi
daft question, does it matter whether you fit the bleed nipple to the front or the rear on the drum brakes. Also do you simply drill a hole in the
sloping side of the rear hub carrier to connect the flexi to the really short copper pipe (any photos greatly appreciated)
I'm finalising my rear brake pipe/handbrake cable route and if I connect the flexi and short copper pipe to the front I'm worried the
flexi and handbrake cable will push each other into the suspension.
Can anyone clarify exactly what constitutes the pipes/cables fouling the rear suspension for SVA
thanks in advance for the assistance
mookaloid
| posted on 14/8/06 at 07:50 PM |
Don't the bleed nipples normally fit at the top?
[Edited on 14/8/06 by mookaloid]
indykid
| posted on 15/8/06 at 12:28 AM |
not if you've got 9" drums.
hang on, i'll find a pic
tom
[Edited on 15/8/06 by indykid]
indykid
| posted on 15/8/06 at 12:40 AM |
this is with the 8" under over brake cylinder, but with the one where one goes forward, one back, send the brake pipe back, and bleed nipple
forward. just makes the flexi run a bit easier, as it puts it in the space behind the wishbones.
the under over cylinder needs tighter bends, but ffs, don't drill the upright!
tom
