jabbahutt
posted on 25/8/06 at 06:50 PM |
vicky green loom and MK
Hi
Can anyone post photos or links to in their archive of where the instrument and steering column wiring on a vicky green loom is in realtionship to the
chassis and how it fits realtive to the scuttle etc as I've temp fitted mine with tie wraps and it looks to be too far forward.
The rear of the loom from the handbrake cable back fits brilliantly but the main cockpit part seems wrong and a picture clears things up easier than
text.
Thanks in advance for any help you can provide
flange nut
| posted on 25/8/06 at 07:47 PM |
I used a Vicky Green loom and I found the same, the rear part was OK but the front end just wasn't right. I ended up stripping the front part
and re-wrapping it with the wires in the right place. I think a Robin Hood must be a fair bit bigger than a MK or Locost.
Geoff
jabbahutt
posted on 28/8/06 at 10:51 AM |
Thanks for taking the effort to reply Geoff. Can anyone help out with photos of the MK scuttle area so I can see where and how the cockpit wiring for
column etc enter the car from the transmission tunnel.
Thanks in advance
