Hursty
| posted on 2/10/06 at 01:53 PM |
Radiator brackets
Hello
I bought a radiator the otehr day from radiatorsonline. I saw on here which to get (I think it was the VW302?) Anyway the radiator came and looks
the job only trouble is I now don't have any radiator brackets.
Can anyone tell me where I can get some or do you have pics and I will have a go at making my own. Any help much appreciated. Cheers.
| posted on 2/10/06 at 02:33 PM |
what do you mean exactly?
the radiator has no brackets or the chassis has no bracketS?
surely the former can't be true otherwise how was it mounted in the original vehccle?
chassis brackets: 2 mm steel, drilled, bent, shaped, welded as required or am I missing the point?
graememk
| posted on 2/10/06 at 02:44 PM |
have a look in donuts photos you will find some pics of his rad mounts from memory
whitestu
| posted on 3/10/06 at 08:32 PM |
I have the same rad - I just made up brackets from angle [to fasten to the holes in the rad]and flat ali bar with rivnuts to fasten to chassis.
Hursty
| posted on 4/10/06 at 07:57 AM |
Thanks for the replies. Whitesu have you any pics?
