tricky262000
posted on 29/12/06 at 07:15 PM |
Rear wishbones
Hi, don't know if anyone has had the same problem as me, but on my indy if the back end is jacked up i can rock the rear wheels side to side as
the front and rear edges of the wheel will move inwards and outwards as if the bearings have got play in them (but they haven't) i can see
movement between the wishbone and hub carrier, if i tighten the bolt up so there is no movement the ride is so hard it hurts, with hte wishbone
tighten right up i can disconnect the shock and lift the car on the wishbone, any ideas would be helpful.
theconrodkid
| posted on 29/12/06 at 07:17 PM |
got the inner steel tube in the bushes?
who cares who wins
pass the pork pies
t.j.
| posted on 29/12/06 at 07:19 PM |
IRS?
Look if the 41mm screw in the middle of the wheel is tightened.
tricky262000
| posted on 29/12/06 at 07:21 PM |
Yes it is assemblied it the correct manner, thats why i can't work out why it's happening, one idea is that the metal inserts are too
short and it's pulling up totally on the poly bushes.
stevec
| posted on 29/12/06 at 07:25 PM |
Have you got spacers either side of the shock?
Steve.
stevec
| posted on 29/12/06 at 07:28 PM |
Like this.
tricky262000
| posted on 29/12/06 at 07:34 PM |
Yes have got spacers fitted the movement is only on the bottom wishbone
stevec
| posted on 29/12/06 at 08:48 PM |
Have you got a total of 4 top hats and 2 steel bushes.?
Can you post a pic of how you have it assembled?
