badding
| posted on 27/1/07 at 04:28 PM |
Remote brake fluid reservoir
Hi
I have the standard ford sierra master brake cylinder,now the problem is that the reservoir from the master brake cylinder is to near to the steering
shaft.
So I want to use a remote brake fluid reservor that can connect to the master brake cylinder...where can I get something like that.
The reservoir needs a sensor for the amount off fluid in it...
| posted on 27/1/07 at 04:33 PM |
Just pull the reservoir off and extend it with some rubber tubes, easy peasy...
badding
| posted on 27/1/07 at 05:09 PM |
does anyone has some pics how they done it.....
TangoMan
| posted on 27/1/07 at 10:32 PM |
I have the same problem except mine is the Throttle Bodies that are restricted by the reservoir.
I am thinking of making up some metal tubes with 2 90 degree bends (left then right) to move the reservoir across by about 1 inch.
Summer's here!!!!
badding
| posted on 28/1/07 at 10:36 PM |
I have taken the reservoir off from the cylinder, was a easy job.
Now I have to measure the original fitting on the bottom from the reservoir and see if I can manufacture them from Alu to put a hose in between, It
seems the rubber grommet isn't damaged by taking the reservoir of.
Will measure the connector and make a cad drawing off it , to have it CNC machined.
badding
| posted on 28/1/07 at 10:37 PM |
And a close up...piccie
badding
| posted on 28/1/07 at 10:48 PM |
I think I make a cad drawing of it to have it CNC machined from ALu, I will post the drawing...By the end off this week...
badding
| posted on 30/1/07 at 08:03 PM |
Here is a cad drawing enjoy....
Left side is the connection on the masterbrake cylinder, the right is where the hose goes to your reservoir when you look at the intersection
drawing...
badding
posted on 30/1/07 at 08:45 PM |
Thanks, now I have to let it CNC fabricated I think form Alu or would you use another metal.....
