Tinks
| posted on 23/2/07 at 03:23 PM |
Radiator spacing
Can anybody give me a rough dimension of how far the radiator (Polo) should be away from the chassis to accept a pull fan at a later date..?
Also is it best to follow the chassis angle or be straight up and down
Thanks in advance
James
| posted on 23/2/07 at 03:47 PM |
Kinda depends which fan.... if you look at my recent post here dimension 'H' is what you want:
http://www.locostbuilders.co.uk/viewthread.php?tid=58221
it has thickness dimensions for Pacet.
According to PPC magazine the most efficient angle at which to have a dual core rad is 20°.
Hope that helps,
James
- Muhammad Ali
Tinks
| posted on 23/2/07 at 03:56 PM |
| posted on 23/2/07 at 05:11 PM |
why do you want a pull fan? push fans are better.
the motor and cowl vary quote a bit between designs; best to find the fan first as sod's law will mean whatever you can pick up cheap will not
fit.
