LBMEFM
| posted on 20/4/07 at 08:09 AM |
Rear drive shafts
Hi
Yet more problems, when fitting my drive shafts (disc brakes) I put the shaft through the upright/hubcarrier, attached the large nut on the end of it,
as I tighten it up the flange at the end of the drive shaft rubs on the inner face of the upright. Any ideas whats occured?
zxrlocost
| posted on 20/4/07 at 08:26 AM |
do you have the ABS drive shafts
theres like a little ring of teeth all the way round the shaft this is most likely hitting the hub
MK should tell people this
you need them machining off mate
only down to the bottom of the teeth
LBMEFM
| posted on 20/4/07 at 12:56 PM |
Drive Shafts
Yes there are a ring of teeth, I will have these machined off, thanks for the advice.
Regards
Barry
