jabbahutt
posted on 1/8/07 at 02:53 PM |
coolant hose location
Hi
i'm fitting the coolant pipes at the moment to a 2.0 pinto Indy. I was considering fitting the pipes that trvel from the front of the engine to
the rear above the exhaust manifold as if there is a problem they're easilt accesible.
The expansion tank in fitted to the battery tray/bulkhead, do you think that fitting the pipes above the exhasut would be too high and cause and
problems with air locks etc?
thanks
Nigel
DarrenW
| posted on 1/8/07 at 03:01 PM |
Mine runs below the exhaust manifold. i used samco bends and a length of ali pipe with flared ends along here. Secured with brackets and clips etc.
I think copper pipe and solder fixings are another solution others have used.
phoenix70
| posted on 1/8/07 at 06:17 PM |
You really need that pipe to be lower than the bottom of the expansion bottle, so running it under the manifold is the better option. Mine run under
the manfold.
indykid
| posted on 1/8/07 at 07:03 PM |
yep. mine runs under in copper and solder ring fittings.
tom
jabbahutt
| posted on 2/8/07 at 07:24 AM |
many thanks for clarifying this for me. Looks like they're going under the manifold.
Thanks again
Nigel
