paulmw
| posted on 8/8/07 at 09:56 AM |
Quick Questions
I got some 15" wheels from ebay. They have an offset of 40 does the 2mm matter compared to the recommended ET38 or will I need spacers?
Also, the handbrake cable on one side pulls through the hole in the chassis. Do I need a washer on it as the other side has the plastic nut thing
Thanks Paul
| posted on 8/8/07 at 10:28 AM |
Usually the end without the plastic adjuster nut has a shaped sleeve that sits in a retaining tube on the chassis. You definitely need to secure the
outer tube somehow else the handbrake will only work on one side.
Personally I wanted the plastic nut adjusters on both sides so got two cables, cut them in half and used the adjustable bit for both sides of the
car...
matt_claydon
| posted on 8/8/07 at 11:31 AM |
IMO, don't worry about the 2mm - it won't be enough to make any difference.
paulmw
| posted on 8/8/07 at 01:17 PM |
quote: Personally I wanted the plastic nut adjusters on both sides so got two cables, cut them in half and used the adjustable bit for both sides
of the car...
Great idea, I cut the original cable too short so have another on order. I can now have 2 adjuster - problem solved -cheers
[Edited on 8/8/07 by paulmw]
