greggors84
| posted on 3/11/03 at 08:38 PM |
Oil Filler Cap
As the neck for the filler cap has to be removed and placed nearer the back of the engine, so that it doesnt catch the bodywork, i was wondering if it
could simply be chopped down and lowered, as in my wonderfully artistic impression below
  Rocker Mods
Chris
The Magnificent 7!
Viper
| posted on 3/11/03 at 09:36 PM |
That's about what i intend to do with my Avon, gonna get it as flush as ai can and put a breather in the rear of the cover.
Mark Allanson
| posted on 3/11/03 at 09:52 PM |
I put parts of the original sierra downpipe on the back of the rocker cover, just level with the top of the cover, welded a plate into the hole left
by the original filler pipe. I will post an image when the upload bit comes back (see website problems)
MK7
| posted on 3/11/03 at 10:04 PM |
Phil at MK suggested getting a low profile cap from a transit diesel, around 1987. Anyone out there done that?
greggors84
| posted on 3/11/03 at 10:16 PM |
Phil, told me that aswell, went along to the scrappy and bought one, but it was exactly the same.
I needed a new one anyway so it didnt matter. Im not a brilliant welder and havent got any welding equipment to hand. So i though just chopping it
down would be easier. Also means you have got a big dent where the old hole has been covered up.
Chris
The Magnificent 7!
CairB
| posted on 3/11/03 at 10:24 PM |
MK7,
I used a cap from my road going 1.8 Sierra, 1987 model, that had a lower profile cap than the 2.0i in my Indy.
It is close to the nose cone, in fact very close, but I think I got away with it and saved moving it.
[Edited on 3/11/03 by CairB]
bob
| posted on 3/11/03 at 10:39 PM |
I think colin is right,i reckon i could have got away without moving the filler.
I know conrod managed to leave it as it is on his indy.
MK7
| posted on 3/11/03 at 10:48 PM |
I don't think my bonnet's going to fit without a bit of work.
I'm wondering if the engine hasn't been raised a bit by the guys at MK recently.
I raise this cos I was reading the 'which kit?' build in which they said they needed to raise the engine mounts by a couple of mm to give
the exhaust some clearnce over the top rail.
In my case (June 2003 chasis) the exhaust clears the top rail by a mile but the bonnet (Which I bought with a bulge in the mistaken understanding that
it would clear the filler cap) doesn't clear the filler cap.
Having said that, at the bottom end, my bellhousing sits about 10 - 15mm below the bottom rail so if they have raised the engine then this was
probably a good thing.
Russell
P.S. Thanks for the pointer Colin, did u find out about the shorter speed drive cable or one with a 90 degree bend? :-)
CairB
| posted on 3/11/03 at 11:00 PM |
MK7,
Drifting off topic, but for starters have a look at http://www.locostbuilders.co.uk/viewthread.php?tid=5949
A quick Google came up with:
http://www.speedograph-richfield.co.uk/Default.htm
No connection.
Colin
Dusty
| posted on 4/11/03 at 01:18 AM |
Speedy Cables do a right angle drive for the type 9 box which I have had running for three years.
James
| posted on 4/11/03 at 05:43 PM |
For mine I first of all whipped the tappet cover off a VW Golf conveniently abandoned near me.
From this I took the filler cap and also cut out the filler hole into which the cap fits.
On the Ford tappet cover I first cut down one side of the baffle so as to bend it out the way. I then cut off the filler tube and opened out the hole
to about 50mm (to match the VW one).
I then gas welded the VW filler hole in place of the Ford one. Job done- total cost 0.00p!!!
When fitted, the top of the cap sticks up only about 15mm above the cover.
I'm about to fit a small vent pipe at the back.
HTH,
James
[Edited on 4/11/03 by James]
