| posted on 7/1/04 at 02:02 PM |
Q for Cairb ???
Colin,
I was looking through an old thread on master cylinder pushrods, where you mentioned you had used the Merlin Motorpsort adjustable pushrod and clevis
assembly.
I have just ordered one of these and was wondering how much you had to modify it to fit the Indy?
Any pics of your pedal set-up would be much appreciated.
Nick
CairB
| posted on 7/1/04 at 06:28 PM |
Nick,
I ground a cone on the end of the push rod that fits into the piston to be similar to the one that was on the end of the servo rod that it replaced,
after cutting it to a length that would give suitable adjustment.
Colin
| posted on 7/1/04 at 06:47 PM |
whilst we're here, are you going to use a return spring of any sort? was just thinking about mine today you see! thanks.
| posted on 7/1/04 at 07:06 PM |
Pedal Assembly
We haven't used a return spring - yet! Waiting to get it out on the road to check feel etc and whether it will return properly.
We have used a clevis from MK which we feel is slightly tidier and less inclined to get stuck in your socks when you have your clogs on...
Picture attached:
  Brake Pedal Assembly
CairB
| posted on 7/1/04 at 07:42 PM |
Joelp,
No, I haven't used any additional return springs, only those built into the master cylinder. I've not noticed any problems on the road.
Colin
| posted on 7/1/04 at 10:07 PM |
nice one, i'll leave mine as it is then! thanks.
Stu16v
| posted on 7/1/04 at 11:34 PM |
Hellfire, just looking at the piccy, is it an optical illlusion, or are some of the welds in the R/H corner (by the throttle pedal) not 100%?
It looks like the diagonal hasnt been welded underneath (not a big strength issue), but it doesnt *look* to be fully welded where the three lengths of
25mm box meet either....
Or am I just seeing things mate?
| posted on 8/1/04 at 08:55 AM |
Colin,
Thanks for the info. and photo, much appreciated.
I shall be fitting mine over the weekend and testing the braking system - fingers crossed!.
Nick
