Can anyone show me how the radiator is supported in the avon, pictures would be greatly appreciated. I have the radiator but no mounts, also in hope
that i am fitting it the right way up.
Cheers Thierry
go to this website
http://www.avon-kitcar.co.uk/
there are some pictures on there that will help
As the previous post. Rad rests on extensions to the bottom front chassis rail and is held in place by a bracket at the top. The hoses also help to
hold it in place. A lot of builders ditch the Tiger radiator and replace it with a VW polo one (me include) which is smaller so will sit vertical an
is also aluminium which is obviously a lot lighter.
[Edited on 20/1/09 by welshavon]
Have a look on my website, i think i've got a shot of it in one of the videos i did, jamie
i would stronly recommend fitting a polo rad as the standard tiger ones are cr@p
Ed
having got a tiger one i fitted it. Here is a picture of how i did it. I made two brackets at the botton in alloy to stop the rad moving sideways
and the made a u bracket at the top which bolts throuth the top chassis rail. Hope this helps. When it fails I will probably change it out for a
polo one.
Picture of the top
