SVA nut covers i got some but i need one for the bottom ball joint it is a 22mm nut do i use a nut cover or is there another way round it and if soi onlky need 2 please help and some pictures would be nice thanks............
I used clear hose with clear silicon.
for some reason they fell off after the test
see photo 17 (The last one).
http://www.locostbuilders.co.uk/viewthread.php?tid=25344
I used the smaller nut covers but used heat shrink to hold it on. Mine are still on.
I used heat shrink on the track rods too.
File the sharp edges on the locking nuts on the top ball joint. Dont use tape, they dont like that.
BTW SWTOC met at Castle Combe yesterday, good day. In 2 weeks Castle Combe meet and then BBQ after, why not come along.
i was there but i did not see anyone there was no cars there i only saw a striker and a red westfield
Think I saw that one , Kawasaki powered if I remember. 3 Tigers were in the car park behand Quarry. Mine was in the paddock on a trailer.
2 bits of heatshrink over each nut did it for me, I found big enough stuff in B & Q.
i used water hose/rubber strip cable tied in place.easy to do but strangly mine fell off too soon after the sva?
scott
i think i have sorted it i was looking at my jack handle the plastic cover on the endi removed it from the metal bar and cut some of and it fitted ok
it was a bit tight
but it fits ok....
