Hi, I have just got back from Harrogate and seen the avon.
Does anyone have a comprehensive kit list for a zx9r build? so I can do some number crunching.
Interested to hear of anyones experiences with putting a bike engine in this car.
Ta
You can buy my SVA'd one for £4750, flog the car engine and put a bike engine in it.
Pat...
andrew, have scanned in the list of what you get in the comp kit (its in my archive). Prob need to go through with a tooth comb and figure out what
you really need. I was (and still am) fairly green to the kit car game and thought it was easier to just take the full kit. I have since changed my
mind on engine, fitted floor mounted pedals and will probably get better seats...
[Edited on 13/8/05 by shades]
I'm in the middle of putting a 'blade engine in my Avon.
Not the easiest thing to do as there are no bespoke items you can buy from Tiger to do this. So everything has to be made as a one-off such as
designing and making a cradle, adapting or having made a manifold, propshaft etc.
However, Chester Sportscars have fitted ZX9 engines in a few of their Avons so it should be well worth your while contacting them for advice.
Andy.
I can give you this!!!!
Total £6687.88 and 2 years
Qty Description Partcost
1 ford sierra 2.0 glx H reg_DOHC £200.00
1 scrap yard charge £20.00
1 tiger Avon book £19.99
1 how to build a sports car book £17.99
1 steel tubes £62.33
1 fibreglass body work £50.00
2 rear uprights £32.00
1 spark plugs 4 off £8.99
1 extra steel £20.79
1 set of poly bushes 20 off £80.50
1 bush tube £0.00
1 2 back plates £26.23
1 Suspension parts +roll bars £63.00
1 SVA Book £18.00
2 bottom ball joint plates £10.00
2 bottom ball joint £8.50
1 wishbone steel £46.30
1 rose joints £39.00
1 suspension bolts £20.07
1 paint(Diff) £20.80
1 diff oil seals £22.33
1 9.9mm drill bit £6.39
1 bodywork-price - book £380.10
1 grill £30.00
1 steering rack £114.00
2 track rod ends £7.50
1 rivets + clamps £22.00
1 bushes m8 £2.55
2 alloy sheets £0.00
1 rose joint + eye bolts £15.03
1 paint(Chassis) £27.61
1 cortina uprights(Pair) £90.00
1 brake discs+wheel bearing £138.11
8 wheel studs £0.87
1 m8 bolts £3.50
1 1/2 inch nuts £1.80
1 Shot blast cleaning (chassis) £40.00
1 brake pipe £4.00
1 p clips £4.00
1 nut covers £2.95
3 sikaflex £8.45
1 inlet manifold £38.01
1 bolts £10.00
1 master cylinder £15.00
1 rivets and bolts £12.00
1 wax oil £27.99
1 steering bush £2.63
1 steering wheel £5.00
1 rubber strip £6.00
1 brake pipe fitting £7.50
1 clutch £37.99
1 uj's for steering £10.00
1 floor mounted pedal box £90.00
2 master cylinders £20.00
1 bolts £1.18
1 paint £13.00
1 bolts £3.00
1 4 way brass tee joint £8.50
1 brake light switch £11.50
1 Callipers and Pads £110.00
1 paint for callipers £6.50
1 remote res £39.00
1 flex hoses front £56.00
1 flex hoses rear £15.63
1 brake fluid £10.00
2 banjo bolts £4.60
1 Brake Fluid £5.95
2 Seal kits £13.50
2 Engine mounting £4.80
1 Selection of metal disks £5.00
1 handbrake clips £0.85
1 handbrake cable £16.00
1 wiring loom £100.00
1 petrol pipe £4.50
1 oil pressure switch £3.50
1 coil £15.50
1 horn £6.50
1 Radiator £40.50
1 alternator £25.00
1 Engine Pinto £30.00
1 Radiator Switch £9.00
1 radiator hose and clips £16.00
1 oil tank filter £7.50
1 electrical bits £4.50
1 exhaust header £50.00
1 electrical bits £15.00
1 ecu £5.00
1 distributor £15.00
1 Radiator Fan+ elect fitting £70.00
1 Fuel pump £50.00
1 Filler Neck £15.00
1 spring and dampers £399.50
1 carbs +propshat £440.00
1 Filler Cap Petrol £89.75
1 stainless bolts £15.75
1 clutch cable £2.00
1 Gasket Set (Pinto) £22.50
1 Alloy Cooling Pipe £4.50
1 Valve Spring Clamp £9.50
1 Gearbox oil seal rear £0.00
1 Paint £2.50
1 Hose and clips £10.80
1 Rubbing compound £0.00
1 Prop shaft balanced & UJ £40.00
1 Filler Pipe £8.50
1 Set of Dash Lights £17.50
1 Tank sender unit £15.00
1 P Clips £3.50
1 Breather Take off £9.50
1 Track rod end covers £3.50
1 C Spanner £5.00
1 petrol pipe+ Clips £7.50
1 Seal + Screws+ M5 nuts £7.00
2 Hose clips £1.50
1 Sprocket puller £13.99
1 Paint + Filler Cap+ Sump Plug £12.50
1 Type 9 gearbox £30.00
1 Start button £17.99
1 timing belt + Plugs etc £15.00
1 Gearbox oil seals release bearing £26.94
1 rubber boot £6.36
1 spring clip £1.70
1 Gear oil £6.00
1 fan belt+ valve grinding past £6.95
1 Battery £32.00
1 inlet gasket £3.00
1 side repeaters £4.00
1 fr32k £246.75
1 Adjustable Pulley £103.40
1 carb Fitting Kit £29.00
14 Manifold Studs £0.88
1 Dial Gauge £30.00
1 Engine Oil £10.99
1 exhaust wrap £35.25
1 water pipe £2.50
1 Paint & wet and dry £8.50
1 Set of lights £99.50
1 Set of rear bulbs £3.50
1 connector blocks £4.50
1 Safety Harness (pair) £65.00
1 Rubber Extrusions £11.50
2 Cable ties £1.10
1 Mesh for Grill £4.95
1 Glue £2.50
1 Spade terminals £4.00
1 Silencer £117.00
1 Carpet & Trim £60.00
1 Seats deposit £20.00
1 Glue Contact £5.50
1 Glue Impact £6.00
1 Tadpole trim £4.00
1 gear stick gaiter £2.00
1 Seats £256.13
1 Carb Balancer £26.90
1 Stainless bolts £3.50
2 Mirrors £33.70
1 Steering Wheel £19.99
1 Handbrake Cover £12.99
1 Locking Wheel Nuts £29.99
1 Steering Wheel Boss £20.00
1 SVA Steering Wheel Pad £20.00
1 Set of Clock' & Dials £299.99
1 pipe lagging & Steel tube £5.50
1 Alloy wheels £130.00
1 electrical bits £3.75
1 Glue & Set screws £3.20
1 New Spark Plugs £9.49
1 heat sink £6.00
2 Tyres £25.00
1 Tyre fitting £6.60
1 new manifold-£40 for the old one £55.00
1 Alloy Valve Caps £4.99
1 Centre mirror £12.99
1 Cycle wing brackets £3.00
6 P clips £0.10
1 Tadpole trim £0.80
1 Ploy Bush £0.00
1 tax disk holder £12.99
2 jubliee clips £1.99
1 oil cap £3.45
1 fire extinguisher £12.99
1 Reed Switch £15.00
8 wheel studs £1.49
1 Mesh for bonnet vent £4.95
1 Six pack magnets £4.50
1 O ring etc £5.00
1 Reg Plates £9.50
1 sva £150.00
1 DVLA £35.00
1 tax £97.50
1 insurance £189.00
and a partridge in a pear tree !
