Hello,
Which mastercylinder (make and type) can I use to build in my tiger?
My retailer doesn't seem to find a suitable type.
regards,
JP
I used the one off the Sierra donor car.
HTH,
James
you have to be careful as they showed one on the original avon before they changed the chassis and the pedal holder assembly part. I had one of these orignal types and it wouldnt fit properly. If you call sue shell let you know the right type. I ended up buying a new one from her in the end for safety/hassle sake etc
In Italy I do not be able to find sierra MC pre 1987, so I do little modification and install a Fiat Uno MC. (Tiger MC pushrod with uno MC fit
perfect).
Sierra MC have diameter 22mm
Fiat Uno Master Cilinder have diameter 20.64 mm.
So I think if you have to modified bracket then use anykind of master cilinder, but remember sierra diameter 22mm.
Another image
