Could someone give me the distance between the two inner brackets upper-lower from a TIGER?
I've made it 220 mm but the locosters have 205?
In my 3D drawing there is no bumpsteer and enough camber.
The rollcentre is about 45 mm above surface. i'm gonna use the cortina uprights
I think I do not understand weel, if you post a pict I will measure mine and let you know
Here is the picture:
220_6 as drawing vs locost 205
[Edited on 2/5/07 by t.j.]
I did measurament: 224, 225 mm circa.
I measured the old tiger braket, I did new brakets in order to use sierra uprights. So the measure is refer to the genuine tiger braket.
