After a busy weekend .....
Dash
Dash awaiting padding........
Very nice!
Look foward to seeing it with covering on it...
Im so not looking forward to making mine sometime in the next few weeks...
looks good that mate
You may know this but when you pad the dash its good to glue to foam to the dash but not glue the vinyl to the foam- just secure it at the back. This
helps prevent any wrinkles from forming
Thanks for the tip....
I am a little worried about when i snip darts into the overhang that it may cause rips to run round to the front?
I have now glued rubber tubing along the bottom edge and intend to pad and cover over the top of that to give the required radius/softness....
I deduce that
a) you are quite tall
b) have forearms like popeye.
6'3" and a quick rack fitted........
I needed the 10" wheel or my legs won't go underneath!
cheers
Dave
Who's gauges are they...??
Very nice
Pete
Originally posted by PeterW
Dave
Very nice
Pete
Dave
Very nice
Pete
Daves![]()
Hey Dave,
You have some problem with your alternator, engine is running at 1800 rpm and alternator do not charge
BTW I like you dash
Gauges are teleflex from haneline in California.
(there was a thread all about them a while back)
I noticed the rev counter appeared to be reading 1800 rpm... I am hoping that will sort itself out when it is wired in and isn't bust
Also - indicator stalk will be shortened so it does not block the view
[Edited on 16/5/07 by DaveFJ]
Hey Dave,
your rev counter is ok, I have one similar in my boat, when you supply it , it will go ok. And when you will turn engine off it will still show for
example 800 rpm until you turn key on (mine do in this way).
Great that's what i had hoped
cheers
Dave, another tip. Bring the vinyl material inside the night before and leave it in a nice warm place. Airing cupboard or near a radiator. It will
help with the stretch and will stop and wrinkles forming. Its the same technique as when fitting a vinyl roof, always wait until a nice warm sunny day
so that everything is supple. hth
Had a go at the covering last night... results weren't bad but I may strip it off and try again depending on how it looks when i get home tonight.......
I am impressed from the rear of the car! That tyres looks very good
Looking good Dave, you did get inspired at the show!!
Looking good
now if i can only figure out the Tiger wiring loom!!!!
Cheers![]()
now if i can only figure out the Tiger wiring loom!!!!![]()
At least its only a pinto loom. My recommendation, start at the dash and work out from there
I have worked out the dials and warning lights so that's not too bad but spent an hour last night working out the light and fog switches. problem
is it bears no greta resemblance to Tigers wiring diagram and all the ifo available only tells me tat 'these 5 wires' are for the light
switch... or whatever... so having to try and trace each wire to work out if it is main/dip/earth etc....
Still it wouldn't be fun if it was simple would it?
