ayoungman
posted on 16/5/05 at 08:05 AM |
progress at last !
Having spent some weeks organising various things, I spent Saturday putting the engine in the Avon ! I think its in the right place ! !
"just like that !"
| posted on 16/5/05 at 08:57 AM |
Couldn't see the full engine/image as it was round the back of my monitor!
Nice installation!!!
mookaloid
| posted on 16/5/05 at 10:22 AM |
looking good
Youe are going to need a very long HT lead from the coil to the dizzy
Have you got your cam yet? I have a Kent FR31 (fast road) going begging if you want it
Mark
Avoneer
| posted on 16/5/05 at 11:03 AM |
You also need to brace the steering mounts at the top with each other and with the chassis - SVA fail if you don't as Tiger engineering means
they flex upto 10mm.
Pat...
| posted on 16/5/05 at 11:07 AM |
looking good
I like the chassis colour too
DaveFJ
| posted on 16/5/05 at 11:10 AM |
looking good
a minor point - I wouldn't leave the brake pipes un-blanked - you never know what is going to find it's way up there !
Dave
| posted on 16/5/05 at 11:17 AM |
Very clean
I like the engine mounts, are they hardwood, softwood or plywood .
ned
| posted on 16/5/05 at 11:54 AM |
what are those clips you've used for the brake lines? are they just two p-clips joined together or a special double p-clip type thing? i'm
after something similar for my fuel line for running both line and return..
Ned.
beware, I've got yellow skin
ayoungman
| posted on 16/5/05 at 02:11 PM |
clips
They are just two P clips overlapped. Fortunately, they fit the width of the chassis rail nicely. The engine blocks are pine ! Well, what would you
expect a Design and Technology teacher to use !!!
Sorry, Mookaloid, cheers for the offer, I've got a cam already lined up for the job !
[Edited on 18/5/05 by ayoungman]
"just like that !"
Monkeybasher
| posted on 24/5/05 at 11:42 PM |
Pat...
Fookme , Mine passed couple of weeks ago at newcastle, however If its that bad I will add a brace.
ayoungman
| posted on 25/5/05 at 04:23 PM |
I'm unsure whether to strengthen this . I do still have engough access to it to put in a diagonal brace. Is it really a SVA faillure without ?
How many Avons has this been an issue for ?
"just like that !"
Lightning
| posted on 25/5/05 at 07:38 PM |
Mine passed without a brace and so did the one from Which Kit who i saw at the test station.
Avoneer
| posted on 25/5/05 at 09:16 PM |
Mine failed without a brace - you can easily bolt a 25x3mm bar across the top two steering rack mounts using the steering rack bolts and then continue
it onto the front upright chassis rail.
Pat...
DarrenW
| posted on 26/5/05 at 09:38 AM |
Are your headlight brackets OK?? look a bit sharp to me.
ayoungman
| posted on 27/5/05 at 08:11 AM |
I'll fetch me angle grinder.
"just like that !"
