wombat
| posted on 21/1/14 at 08:17 PM |
Fitting fuel sender
What is the best way of fixing the fuel sender into my brand new tank without getting swarf inside?
Barkalarr
| posted on 21/1/14 at 10:18 PM |
Drill it upside down.
You'll still need to give it a swoosh round with petrol, but that's what I've just done with mine.
wombat
| posted on 22/1/14 at 07:29 AM |
Is it then a self tapper fixing?
Barkalarr
| posted on 22/1/14 at 07:30 AM |
Yes.
neilp1
| posted on 22/1/14 at 03:58 PM |
I used masking tape sticky side up inside and then drilled & tapped hole making sure I took my time.
wombat
| posted on 22/1/14 at 04:02 PM |
Thx, upside down it is, was just talking to mate at work who suggested the masking tape too !
Barkalarr
| posted on 22/1/14 at 04:18 PM |
I guess you're going to mount your sender close to the filler cap so you can get in there with the sticky tape??
Like an idiot, i managed to cut out my sender right where the mounting brackets are so I had to make some new ones which straddle the sender - so make
sure the sender missed the mounting brackets.
I used self tappers in my sender ..
[Edited on 22/1/14 by Barkalarr]
wombat
| posted on 22/1/14 at 04:32 PM |
The Avon tank comes with the sender hole pre drilled, so not a problem.
It will be a case of taping a couple and drilling then the other ones, fiddly but ok.
What did you use for the anti spill / roll over/ one way valve?
Did IVA ask for any paperwork for this?
You can buy one way valves from 4.99 to 40.99 from what I can tell....
