marshall
| posted on 17/1/05 at 04:15 PM |
alternator bracket
hope someone can help i have a 2.0 EFI pinto i have removed the inj/unit and put on carbs on i was going to put the alternator (lucus 101) on but the
bracket looks to big has smeone dune this and what was dune pictures if poss thanks.
Mark Allanson
| posted on 21/1/05 at 09:59 PM |
I don't know about the space available in an avon, but the sierra alternator would not fit in my book chassis. I fitted a Kia Pride unit, with a
bespoke lower bracket and the kia upper bracket inverted. It works fine and if you fit the same as me, you will need a 813mm belt
marshall
| posted on 24/1/05 at 03:08 PM |
were do i get these brackets from and
is the alternator easy to get hold of
Mark Allanson
| posted on 24/1/05 at 03:33 PM |
The brackets come from any steel sockholder - just ask for 3mm plate!
The alternator is easy to get hold of, there aremore prides in the scrappies than out of them. The pride is the same as an early Mazda 121, so other
Mazdas may be similar
