studon
| posted on 3/2/05 at 10:26 PM |
Brakes!
I am now ready to fill the system with brake fluid
having now sussed the rear brake calipers (Ta Steve!)
Has anyone had issue with the machined 'plunger' that Tiger supply? I have fitted it as is. I am just concerned before I waste time and
brake fluid that maybe it wont work? has any body out there had problems with it? do I need to modify it in any way? or is it one of the rare parts
that does not need to be fiddled with?
ta
Stuart
Avoneer
| posted on 3/2/05 at 11:50 PM |
If you're talking about the plastic plunger on the rear brake back plates, I just cut mine right down and pushed them back in.
Pat...
tractorboy
| posted on 4/2/05 at 01:17 AM |
if your talking about the plunger from the brake peddle to the master cylinder . with mine i took a fraction off of the fwd end with some emery paper
and at the peddle end i used a self centering nut as a stop ,this is because the peddle moves in an arc and the plunger moves in a straight line . i
can post photo if my explanation has got confused in the translation.
scott
DaveFJ
| posted on 4/2/05 at 09:01 AM |
scott
A self centering nut ? some piccys would help....
Dave
Avoneer
| posted on 4/2/05 at 01:16 PM |
I got the white plastic "bead" off the SIerra plunger (I take it you mean the master cylinder push rod).
Pat...
studon
| posted on 4/2/05 at 06:47 PM |
Yep.
sorry I was not that clear..
I do mean the push rod into the master cylinder
Avoneer
| posted on 4/2/05 at 07:38 PM |
Yep, the white bead from the Sierra one is the one to use - you just have to make the hole a little bigger.
Pat...
