Hi
Had a new exhaust made for my dax rush,
Its a 6" can with stainless steel ends and aliminuim body, 2.5" straight through.
Idea is that the ali body will keep it cooler,
Should be good for under 98 DB and proven to be,
this can not including tail pipe is 36" long and will have a removable 4" cat inside 200 cells psi,
So hopefully will assist with immisions for sva,
These cans are exceptionally well made and by a friend of mine who works for a well known kit car company,
He can make cans any size in ali or stainless, so if any one want anything made give me a u2u and i can find out prices for you depending on what you
want,
and also can arrange for full fitting service including link pipes,
The can at mo has temp screws one end to gain access to cat to remove after sva ( of course for track days only not road use)
but can be riveted or dome head screws etc depending on each persons needs,
hope you like it??? picutures attached
u2u if anyone want a good can high quality and will get you on trackdays and not stuff up performance of your car because you need a db killer
pic 2
BOOTYFULL!!
Ballpark price?
exactly what I am after in the new year after my 107 static test result at brands
can you u2u me rough cost and contact details etc. Im based in croydon and have a 2003 R1 engine mk indy!
looks great btw
Hi forgot to mention the cost of this can,
its very large as said and including link pipe and full fitting of the can
£340 all in
i was well happy as you can pay upwards of this for just a can and i have done in the past, not including any fitting,
but again it depends on size as materials for this alone to make was over £100,
hope this helps
