Hi All,
I now have my engine cradle mounted and engine in.
Need to sort out a gear change kit.
I bought a modified lever to go onto the engine.
I have looked at cable kits that come with a gear knob as such but they are coming in at £180+vat which I think is a bit expensive for what it is
unless I'm missing something.
My car - Westfield
Engine - ZX9
you need something like this I believe:
VW BUG BUGGY MORSE THROTTLE CABLE 9 FT BULK HEAD STYLE PUSH PULL CABLE
a push/pull cable (morse/teleflex etc)
then if you want a 'stick shift', just a tube with a pivot, knob on the top and the cable bolted below the pivot with a rose joint on it
I think....
It was this kit I was looking at.
http://www.mksportscars.com/parts-c3/bike-engine-car-parts-c6/bike-engine-gear-link-kit-p108
But not from MK.
Would I be able to shorten that longer cable?
No you can't shorten the cables yourself.
The cable I Got in the MK kit was way to long for my R1 install
Mark Steggles is selling one on SEVENS SEVENS SEVENS fb page
1.8m with rose joints included £65
SKC - Oh dear!
Check out the MR2 gear lever and linkage. You have to modify it to remove sldeways movement but available for low cost !!
