Another subjective question...
...what are the differences between the blade and the zx9r engines in terms of bhp/torque, refinement, reliability, value?
Which would be the better buy from a value point of view.
Finally (promise), are they both as easy to fit as each other...if you get what I mean
Thanx
Raj
I'd say at the moment, a ZX9 is better value for money than a blade. ZX9's can still be picked up for well under a grand, but blades at this price are
becoming like the proverbial rocking horse poo!
There's pro's and cons to both, but both engines are pretty well supported now and so exhausts/prop flanges/ gear linkages wont be a problem to find
if you want to buy them.
A ZX9 is a little more powerful, about 6-8bhp up on a late blade, but has the disadvantage of being lower overall geared, meaning larger wheel/tyre
combination or a longer diff may be required for reasonable top speed / comfortable cruising. The gearbox on the ZX9 is meant to be nicer to use,
smoother etc, but I can't comment first hand on that as I've never tried a ZX box.
Can't think of too many other pros n cons at the mo, but then it's far too late to think about it really!
Chris
IMHO the ZX9 has a sweeter gearbox and a bit more power. A bit of pain regarding gearing can be overcome with high ratio diff 3.1.
Dont forget to budget for a sump chop so as to mount the engine lower in the chassis.
Unless you want to race in the 750mc series I'd go ZX9 rather than the premium for the Blade.
You could look at an R1 as they are fairly cheap, light and powerful.
Top bargain though would be CBR1000 which are really cheap and fairly bomb proof.
Jim
R1 Phoenix (under construction)
hi all
agree with all of the above also i`m led to believe that the zx produces more torque!
as for gearing check out the graph`s that are on this site they give you all the info your need
regards
Sting
zx9 you know it makes sense
Yup agreed Jim, the only thing to consider is if you are going the traditional Locost live axle'd route then a 3.54 diff is as high as she'll go
unless these custom made 3.2 CWPs get made, but at a price.
BTW, if anyone needs a ZX9 sump chop then let me know, as you may or may not know, my uncle did Jasper's for him at a very reasonable price.
Chris
Chris, I will be needing a chop, would make sense for me to do it before I make up my engine mounts.If you want to discuss details send me an u2u and
I will let you have my email.
Cheers Col
As you know I've gone the ZX9 route. Can't comment on the power/gears as it aint running yet. But no probs getting exhaust (ST) prop flange (MK), I'm
using live axel so will be using 15" wheels. Sump chop - see Chris Gamblin - beautiful. Mounted the engine back into passenger bay 4" and have a dead
straight prop angle.
As for price, mine was £850 from a reliable source, 1999 model, all electrics and dials too, with a genuine 8K on clock, can be got cheaper, but
history more important to me.
Your coming to Box Hill aren't you Raj, we can talk more there.....
Chris, when you gonna bring your BEC to Box Hill one sunday to show the boys what it's all about?????
Hi Jasper
Yeh sounds good, maybe try and organise a few of em to turn up from the Yahoo BEC list, we quite regularly meet up for a Little Chef breakfast and a
tyre kick. When are you next going? The other option is for you guys to pop along to Brooklands (only about 20 minutes from Boxhill), it looks like
we're organising another "track" day there some time in November, so an opportunity for some passenger rides......
Chris
[Edited on 31/10/02 by ChrisGamlin]
Box Hill next meet is 3rd Nov 10am, see the clubs/events section.
Brooklands sounds great...
BTW, if you see your Uncle first, he was gonna pick me up a piece of thin ali to make a sump baffle, but I haven't got over to Midhurst in a while.
[Edited on 31/10/02 by Jasper]
He's got the ally sheet sitting at home, I saw it last weekend so ready to pick up whenever you want. Maybe pick it up at Brooklands, I'd imagine
he'll come along but even if not, I can bring it with me.
Not sure if I can make it along this Sunday, will see how it goes, I might be mechanic-ing for my racer mate at Rockingham, and anyway would be quite
dependent on what the weather is like!! How many do you get turning up usually?
cheers
Chris
We usually get around 6 or so turn up. Weather looks shitty this Sunday...
I'll pick the alli sheet up off you then if I don't get over to Midhurst in the meantime.
keep us informed about the brooklands meet Chris i fancy a look
Will do, it now looks like there is going to be TWO days, one on the 16th and one on the 30th of November, so keep the diaries clear!
Chris
