thanks for all the info on what to disconnect on the electrics. it fired up 1st time after i changed the fuel pump for some strange reason the blade
one seemed to be air locking. how are you guys making the throttle pedal a little heavier mine doesn't appear to have any feel to it you only
need to touch it and up go the revs
tony
Can you move the attachment point from the cable to the pedal closer to the pedals pivot? A little bit will go a long ways to alter the pedal to cable
travel ratio. As long as you still have full throttle with the pedal pressed to the floor that is.
Graber
Originally posted by mad-butcher
how are you guys making the throttle pedal a little heavier mine doesn't appear to have any feel to it you only need to touch it and up go the revs
tony
I knew Id seen some somewhere, these are Blackbird carbs (courtesy of DanB's website) but you get the idea.
Carb spring mod 1
Carb spring mod 2
Or stick a nice big return spring on the pedal. Don't have a pic of mien yet, but here's one of CraigS's:
Yep can do this too, the only benefit this doesnt give is to help the throttle return. On the bike you have two cables, one to open the throttle and one to pull it shut again. Because of this the return springs on the carbs arent quite as strong as on many car carbs so if only running one cable they have been known to stick open on occasions.
