What do you chaps recon to buying an already registered car engined 7 and then converting it to a bec? My initial plan was to buy the whole kit and
assemble it but it seems that this is going to be a little bit to costly for me and I’m not into the building from book idea because I know I will
never get the job finished. Obviously by doing the conversion route there would be personal touches that I would want to change when finances permit!
Is doing a conversion a quicker way to get on the road or is it more hassle than its worth? What is the legal position with converting to bec, do I
need a re-test or anything?
I’m sure I will think of a few more questions but this lot should do for starters
Originally posted by pathfinder
What do you chaps recon to buying an already registered car engined 7 and then converting it to a bec? My initial plan was to buy the whole kit and assemble it but it seems that this is going to be a little bit to costly for me and I’m not into the building from book idea because I know I will never get the job finished. Obviously by doing the conversion route there would be personal touches that I would want to change when finances permit! Is doing a conversion a quicker way to get on the road or is it more hassle than its worth? What is the legal position with converting to bec, do I need a re-test or anything?
colin
we put a larger 2lt motor in a 1.2 corsa no hassle with swansea latter we got hold of a 16v 1.2 engine and tried to register the engine change even
though they had the numbers that said it was a 1.2 they wanted an engineers report and confirmation from vauxhalls apparently they don't mind the
extra duty but don't like lowering the taxation class
tony
I'm an engineer!
Reports £10
No SVA or anything serious though!
