I need a rev counter for blade
mad-butcher - 11/7/05 at 06:00 PM
evenin guys
I need a rev counter to fit a 95 blade I was planning on an elliot at £126 when I noticed a device made by datatool called revlight in the demon freaks catalogue at £59 has any-one used one of these. also what is the average safe rpm for the bloodline on a blade
many thanks
tony
ChrisGamlin - 11/7/05 at 07:26 PM
The blade red line is at 11750, this is where the limiter cuts in, but Id set your shift lights to change at around 11k as you dont really gain anything by going above that if the engine is standard.
If I were you Id look to have something that at least indicates your actual revs and dont just use shift lights, its useful to know your RPM sometimes even when not red lining it.
