if i bought one of the above does it have to come of a 250cc or 400cc bike , and is there some kind of mod i have to do with the wiring .
anyone done it before ??
cheers
simon
Have sent a U2U for you.
Rich.
In case it helps anyone else out here's the wiring required for the Superdream rectifier here it is as taken from one of the bike sites so if
it's wrong don't shoot the messenger!!
The 3 yellow wires that come out from the finned unit which usually has a red shiny sticker on with 12v stamped on it go to the 3 yellow wires that
already go to the blade rectifier.
It dosent matter which 3 wires go to which 3 yellow ones as long as they are connected.
There are also a green, black and red wire coming out of the finned unit also.
Ground the green wire to the frame.
connect the Red wire to + wire coming from the blade starter relay (RedWhite on mine).
Black wire to the main +12v feed that comes from the ignition switch to the rest of the bikes electrical items, the same wire that only has 12v on it
while the ignition is on. (This is important as it lets the rectifier know when the ignition is on, if it is not connected the regulator thinks the
battery has 0volts and send a big charge to it which can fry the battery)
HTH,
Rich.
whats the benifit of one of these rectifiers in comparison to the original fit ones ?
Diagram here http://www.shortshouse.co.uk/
HTH,
Rich.
thanks for the info guys
