Hi all shoud have gone to Brands this morning ,Droped the wife in to work then set off (8.30 Cardiff) Rear Brake calliper decided to stay on the tin
top ,smell of vhot pad and hub so back home and TOOK IT OUT ON THE CAT!!!!!!.jpg)
So cut it to bits and make it fit.jpg)
fill the gap.jpg)
tack in.jpg)
quick pollish.jpg)
on ( not for long i hope ).jpg)
next for the chop.jpg)
Lenny,
You probably know this already but watch out for the contents of your cat! There are all sorts of strange chemcials used in the manufacture apparently
and arent all that great if you breathe them in etc!
Sweet bit of welding tho! I removed the contents of my pre-cat on my everyday car and couldnt get the cat casing welded up anywhere near as neatly as
that!
Geoff
