hi has anyone got a wiring diagram for a zx9 b4
or how much difference is there to the zx9 (e)
must be loads
just want it for clutch and stuff !
cheers paul
ive got the haynes book. a quick summary, its switched in the earth from the starter relay. When the clutch is out, it has to earth through the
neutral switch. When its in, its linked via the left handle bar switch straight to earth (only if the handlebar switch is plugged in). You can
assumedly bypass by a direct earth from the starter relay, with anything you want to leave in left in
[Edited on 21/12/05 by JoelP]
