and came across this article.
LINK
Once the engine was running Jamie started the tuning process, the end result a jaw dropping 284hp@9000rpm and 202ft-lbs@8000rpm. And to put those enormous numbers into perspective, they equate to double the rear wheel horsepower and triple the torque of a standard ZX-12R!
Aussie ZX12R is restricted. That will also explain why its the second fastest production bike - in Australia
Joel, if you look at the bottom of the page it says 156bhp (rear wheel) as stock.
[Edited on 1-1-06 by Hellfire]
And here for good info
Carl
Carl![]()
