hi all
i'm about to fit a drysump to my zx12,
and the mechanical waterpump is needed to fit the oilpump.
so an electric waterpump is necessary. craig davies or equivalent
should i use a controller?? what brand ? craig davies?
or run it continious.
use : road /trackdays
thanks koen
Unless you are racing I would say definitely use the CD Controller unless you can hack into your ECU for the control.
Also make sure you get the Mk3 pump which apparently has better bearings.
