Are they 5mm x 1.5 (fine) thread?
Pat...
std pitch for 5mm is .8mm
I recon Chris is right.
Pat, if you manage to find some, let me know
M7 - that's what I meant
Chris, where did you get 8mm by 8mm studs from?
Gav, will let you know and get you some as well - oh, also got a Cat you can borrow for SVA - see my post in Engines & Transmission.
Pat...
Buy a length of 8mm threaded bar and cut your own, it's only about 75p a metre at our bolt shop. Lock two nuts together to install them. put a
nut on before you cut it then dress the end thread before you take the nut off and it will clean it up as you remove it.
[Edited on 15/3/06 by Peteff]
Aaahhh, never knew they were normal 8mm into the block.
Will get some normal studs and normal nuts (and extras for Gav).
Pat...
That would be much appreciated Pat!
let me know the cost and ill PP it across.
And yes id be very interested in hiring your CAT eventually!
Nuts and studs will be free mate.
Cat will as well to you
Pat...
Cheers Pat, much appreciated!
