hi all
does anybody know the main difference's
between the b4 and a c or above ?
i.e mounts, will prop adapter fit ?
as only 3 gears is getting boring now !!
so do i buy a newer engine or fit the same
cheers paul
[Edited on 27/4/06 by ch1ll1]
There was a factory recall on C1 model for gearbox problems so get a C2 or later if you can. You'll need the wiring to go with it.
Hi there
As far as I know the prop adaptor should fit, however the engine mounts are different as the cylender head is not the same.
If you go on to www.kawasaki.com you can get the parts diagrams / numbers and you can compare the differences.
Hope this helps
Ian
